need assembly sample code 89c51 display
harishwww
Member level 3
hi
i want to make display board using assembly code using 89c51 pls any one give me sample code for this circuit
hi
can you post where you are having problem in your code?
also why are both serial inputs of 74164 tied together?
MATRIX FORMAT
ROW & COL ACTIVE HI
COL SCAN BY 74LS164
-----------5
-----------4
-----------3
-----------2
-----------1
-------2 1 0
row 3-7 decoder
a=2.0
b=2.1
c=2.2
column ck,dt
ck=1.6
dt=1.7
#include <reg51.h>
#include <intrins.h>
#define TRUE 1 /* define logical true / false */
#define FALSE 0 /* values for bit variables */
#define SCROLL_DELAY 1 /* scroll delay */
#define TIMER0_COUNT 0xFADA // 1.1ms
void modu1();
void modu2();
void modu3();
void modu4();
void modu5();
void sendCommand(char* command);
void sendChar(unsigned char c);
void delay_us(unsigned int d);
void sort(unsigned char a,unsigned char *d,unsigned char *m);
extern signed char write2464(unsigned int Address, unsigned char Data);
extern unsigned char read2464(unsigned int Address);
typedef unsigned char byte; /* type define objects with */
typedef unsigned int word; /* more classical microprocessor */
code unsigned char matrix[91][7]=
{ 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, // Space
0xFB,0xFB,0xFB,0xFB,0xFB,0xFF,0xFB, // ;!
0xF5,0xF5,0xF5,0xFF,0xFF,0xFF,0xFF, // "
0xF5,0xF5,0xE0,0xF5,0xE0,0xF5,0xF5, // #
0xFB,0xF0,0xEB,0xF1,0xFA,0xE1,0xFB, // $
0xE3,0xEA,0xE5,0xFB,0xF4,0xEA,0xF8, // %
0xF7,0xEB,0xEB,0xF7,0xEA,0xED,0xF2, // &
0xF9,0xF9,0xFD,0xFB,0xFF,0xFF,0xFF, // '
0xFD,0xFB,0xF7,0xF7,0xF7,0xFB,0xFD, // (
0xF7,0xFB,0xFD,0xFD,0xFD,0xFB,0xF7, // )
0xFB,0xEA,0xF1,0xFB,0xF1,0xEA,0xFB, // *
0xFF,0xFB,0xFB,0xE0,0xFB,0xFB,0xFF, // +
0xFF,0xFF,0xFF,0xF3,0xF3,0xFB,0xF7, // ,
0xFF,0xFF,0xFF,0xF1,0xFF,0xFF,0xFF, // -
0xFF,0xFF,0xFF,0xFF,0xFF,0xF3,0xF3, // .
0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xFF, // /
0xF1,0xEE,0xEC,0xEA,0xE6,0xEE,0xF1, // 0
0xFB,0xF3,0xFB,0xFB,0xFB,0xFB,0xF1, // 1
0xF1,0xEE,0xFE,0xF1,0xEF,0xEF,0xE0, // 2
0xF1,0xEE,0xFE,0xF9,0xFE,0xEE,0xF1, // 3
0xFD,0xF9,0xF5,0xED,0xE0,0xFD,0xFD, // 4
0xE0,0xEF,0xE1,0xFE,0xFE,0xFE,0xE1, // 5
0xF9,0xF7,0xEF,0xE1,0xEE,0xEE,0xF1, // 6
0xE0,0xFE,0xFD,0xFB,0xF7,0xF7,0xF7, // 7
0xF1,0xEE,0xEE,0xF1,0xEE,0xEE,0xF1, // 8
0xF1,0xEE,0xEE,0xF0,0xFE,0xFD,0xF3, // 9
0xFF,0xF3,0xF3,0xFF,0xF3,0xF3,0xFF, // :
0xF3,0xFB,0xF3,0xF3,0xFF,0xF3,0xF3, // ;
0xFD,0xFB,0xF7,0xEF,0xF7,0xFB,0xFD, // <
0xFF,0xFF,0xF1,0xFF,0xF1,0xFF,0xFF, // ;=
0xF7,0xFB,0xFD,0xFE,0xFD,0xFB,0xF7, // >
0xF1,0xEE,0xFE,0xFD,0xFB,0xFF,0xFB, // ?
0xF1,0xEE,0xFE,0xF2,0xEA,0xEA,0xF1, // @
0xFB,0xF5,0xEE,0xEE,0xE0,0xEE,0xEE, // A
0xE1,0xF6,0xF6,0xF1,0xF6,0xF6,0xE1, // B
0xF1,0xEE,0xEF,0xEF,0xEF,0xEE,0xF1, // C
0xE1,0xF6,0xF6,0xF6,0xF6,0xF6,0xE1, // D
0xE0,0xEF,0xEF,0xE3,0xEF,0xEF,0xE0, // E
0xE0,0xEF,0xEF,0xE3,0xEF,0xEF,0xEF, // F
0xF1,0xEE,0xEF,0xE8,0xEE,0xEE,0xF1, // G
0xEE,0xEE,0xEE,0xE0,0xEE,0xEE,0xEE, // H
0xF1,0xFB,0xFB,0xFB,0xFB,0xFB,0xF1, // ;I
0xF8,0xFD,0xFD,0xFD,0xFD,0xFD,0xF3, // J
0xEE,0xED,0xEB,0xE7,0xEB,0xED,0xEE, // K
0xEF,0xEF,0xEF,0xEF,0xEF,0xEF,0xE0, // L
0xEE,0xE4,0xEA,0xEA,0xEE,0xEE,0xEE, // M
0xEE,0xE6,0xEA,0xEC,0xEE,0xEE,0xEE, // N
0xF1,0xEE,0xEE,0xEE,0xEE,0xEE,0xF1, // O
0xE1,0xEE,0xEE,0xE1,0xEF,0xEF,0xEF, // P
0xF1,0xEE,0xEE,0xEE,0xEA,0xED,0xF2, // Q
0xE1,0xEE,0xEE,0xE1,0xEB,0xED,0xEE, // R
0xF1,0xEE,0xEF,0xF1,0xFE,0xEE,0xF1, // S
0xE0,0xFB,0xFB,0xFB,0xFB,0xFB,0xFB, // T
0xEE,0xEE,0xEE,0xEE,0xEE,0xEE,0xF1, // U
0xEE,0xEE,0xEE,0xF5,0xF5,0xFB,0xFB, // V
0xEE,0xEE,0xEE,0xEA,0xEA,0xE4,0xEE, // W
0xEE,0xEE,0xF5,0xFB,0xF5,0xEE,0xEE, // X
0xEE,0xEE,0xF5,0xFB,0xFB,0xFB,0xFB, // Y
0xE0,0xFE,0xFD,0xFB,0xF7,0xEF,0xE0, // Z
0xF1,0xF7,0xF7,0xF7,0xF7,0xF7,0xF1, /* [ */
0xFF,0xEF,0xF7,0xFB,0xFD,0xFE,0xFF, /* \ */
0xF1,0xFD,0xFD,0xFD,0xFD,0xFD,0xF1, /* [ */
0xFB,0xF5,0xEE,0xFF,0xFF,0xFF,0xFF, // ^
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0, // _
0xF3,0xF3,0xF7,0xFB,0xFF,0xFF,0xFF, // '
0xFF,0xFF,0xF1,0xFE,0xF0,0xEE,0xF1, // a
0xEF,0xEF,0xE9,0xE6,0xEE,0xE6,0xE9, // b
0xFF,0xFF,0xF8,0xF7,0xF7,0xF7,0xF8, // c
0xFE,0xFE,0xF2,0xEC,0xEE,0xEC,0xF2, // d
0xFF,0xFF,0xF1,0xEE,0xE0,0xEF,0xF1, // e
0xF9,0xF6,0xF7,0xE1,0xF7,0xF7,0xF7, // f
0xFF,0xFF,0xF0,0xEE,0xF0,0xFE,0xF1, // g
0xEF,0xEF,0xE9,0xE6,0xEE,0xEE,0xEE, // h
0xFB,0xFF,0xF3,0xFB,0xFB,0xFB,0xF1, // i
0xFD,0xFF,0xF9,0xFD,0xFD,0xFD,0xF3, // j
0xF7,0xF7,0xF6,0xF5,0xF3,0xF5,0xF6, // k
0xF3,0xFB,0xFB,0xFB,0xFB,0xFB,0xF1, // l
0xFF,0xFF,0xE5,0xEA,0xEA,0xEA,0xEA, // m
0xFF,0xFF,0xE9,0xE6,0xEE,0xEE,0xEE, // n
0xFF,0xFF,0xF1,0xEE,0xEE,0xEE,0xF1, // o
0xFF,0xFF,0xE1,0xEE,0xE1,0xEF,0xEF, // p
0xFF,0xFF,0xF0,0xEE,0xF0,0xFE,0xFE, // q
0xFF,0xFF,0xE9,0xE6,0xEF,0xEF,0xEF, // r
0xFF,0xFF,0xF0,0xEF,0xF1,0xFE,0xE1, // s
0xFB,0xFB,0xF0,0xFB,0xFB,0xFB,0xFC, // t
0xFF,0xFF,0xEE,0xEE,0xEE,0xEC,0xF2, // u
0xFF,0xFF,0xEE,0xEE,0xEE,0xF5,0xFB, // v
0xFF,0xFF,0xEE,0xEE,0xEA,0xEA,0xF4, // w
0xFF,0xFF,0xEE,0xF5,0xFB,0xF5,0xEE, // x
0xFF,0xFF,0xEE,0xF5,0xFB,0xFB,0xF3, // y
0xFF,0xFF,0xE0,0xFD,0xFB,0xF7,0xE0}; // z
code char MSG1[]="your message here ";
sbit LED_CLOCK = P1^7;
sbit LED_DATA = P1^6;
char msg[41];
unsigned char dig[20];
bit CH_LIM,OFF_CH;
byte tmp,t;
void main(void)
byte modu,divi,blank1_limit,blank2_limit,ch_limit;
byte i,j,k,offset_ch,old_divi,diff;
int offset_col,t1;
int row;
P1=0xFF;
P3=0xFF;
P2=0xFF;
EA =0;
TL1=0XFD; //9600 @ 11.0592
TH1=0XFD;
TMOD =0x21;
SCON =0X50;
ET0=1;
TR1=1;
//EA = 1;
RI=0;
main execution loop, executes forever.
LED_CLOCK = 1;
P2=7;
offset_col=0;
blank1_limit=17;
ch_limit=0;
blank2_limit=0;
offset_ch=40;
CH_LIM=0;
OFF_CH=0;
k=0;
for(i=0;i<=40;i++) msg=read2464(i);
for(t1=40;t1>=0;t1--)msg[t1]=MSG1[40-t1]; //store msg
while(1){
if(RI){
P2=7;
sendCommand("TYPE MSG:\r");
i=41;
while(1){
while(!RI);
RI=0;
if(i!=0 || SBUF==13){
if(SBUF==13){
sendCommand("\rOK\r");
sendCommand("Storing....wait\r");
for(k=i;k>0;k--)msg[k]=0x20; //space char
msg[0]=0x20;
for(i=0;i<=40;i++) tmp=write2464(i,msg);
sendCommand("OK\r");
break;
if(SBUF==0x08){
if(i!=40){sendChar(SBUF);++i;}
else{
msg=SBUF;
sendChar(msg);
--i;
if(SBUF==0x08 && i==0){
for(k=0;k<SCROLL_DELAY;k++){
//delay_us(60000);
for(row=6;row>-1;row--){
i=16;
for(j=0;j<blank1_limit;j++){
dig=0xff;--i;
t=0;
for(j=0;j<ch_limit;j++){
dig=matrix[msg[(t+offset_ch)]-0x20][row];
--t;
--i;
for(j=0;j<blank2_limit;j++){
dig=0xff;--i;
if(modu==1)modu1();
else if(modu==2) modu2();
else if(modu==3) modu3();
else if(modu==4) modu4();
else if(modu==5) modu5();
for(i=1;i<17;i++){
t=dig;
if(t & 0x01) LED_DATA =0;
else LED_DATA=1;
LED_CLOCK = 1;LED_CLOCK = 0; LED_CLOCK = 1;
t=t >>1;
else LED_DATA=1;
t=t >>1;
else LED_DATA=1;
t=t >>1;
else LED_DATA=1;
t=t >>1;
else LED_DATA=1;
t=t >>1;
else LED_DATA=1;
P2=row;
delay_us(2000);
P2=7;
}//delay
if(++offset_col>348){ // 96 + 150 + 96
offset_col=0;
blank1_limit=17;
ch_limit=0;
blank2_limit=0;
offset_ch=40;
CH_LIM=0;
OFF_CH=0;
modu=offset_col%6;
divi=offset_col/6;
if(divi!=old_divi)diff=1;
else diff=0;
if(blank1_limit!=0)blank1_limit=blank1_limit-diff;
if(CH_LIM){
if(OFF_CH){
blank2_limit=blank2_limit+diff;
ch_limit=ch_limit-diff;
if(ch_limit==255)ch_limit=0;
offset_ch=offset_ch-diff;
if(offset_ch>41)offset_ch=0;
}else{
ch_limit=ch_limit+diff;
if(offset_ch==16)OFF_CH=1;
if(ch_limit==17)CH_LIM=1;
old_divi=divi;
}//while
}//----------------end main
void sendCommand(char* command){
char index, temp;
index=0;
while(1){ //for(index = 0; temp != 0; index++){
temp = command[index];
if(temp==0)break;
sendChar(temp);
++index;
void sendChar(unsigned char c){
SBUF = c;
while(!TI);TI = 0;
void delay_us(unsigned int d){
unsigned int i,m;
m=d/14;
for(i=0;i<m;i++);
void modu1(){
tmp=dig[0];
dig[0]<<=1;
t=dig[1];
dig[1]<<=1;
dig[1]=(dig[1])|((tmp>>5) & 0x01);
tmp=dig[2];
dig[2]<<=1;
dig[2]=(dig[2])|((t>>5)& 0x01);
t=dig[3];
dig[3]<<=1;
dig[3]=(dig[3])|((tmp>>5)& 0x01);
tmp=dig[4];
dig[4]<<=1;
dig[4]=(dig[4])|((t>>5)& 0x01);
t=dig[5];
dig[5]<<=1;
dig[5]=(dig[5])|((tmp>>5)& 0x01);
tmp=dig[6];
dig[6]<<=1;
dig[6]=(dig[6])|((t>>5) & 0x01);
t=dig[7];
dig[7]<<=1;
dig[7]=(dig[7])|((tmp>>5)& 0x01);
tmp=dig[8];
dig[8]<<=1;
dig[8]=(dig[8])|((t>>5)& 0x01);
t=dig[9];
dig[9]<<=1;
dig[9]=(dig[9])|((tmp>>5)& 0x01);
tmp=dig[10];
dig[10]<<=1;
dig[10]=(dig[10])|((t>>5) & 0x01);
t=dig[11];
dig[11]<<=1;
dig[11]=(dig[11])|((tmp>>5)& 0x01);
tmp=dig[12];
dig[12]<<=1;
dig[12]=(dig[12])|((t>>5)& 0x01);
t=dig[13];
dig[13]<<=1;
dig[13]=(dig[13])|((tmp>>5)& 0x01);
tmp=dig[14];
dig[14]<<=1;
dig[14]=(dig[14])|((t>>5) & 0x01);
t=dig[15];
dig[15]<<=1;
dig[15]=(dig[15])|((tmp>>5) & 0x01);
tmp=dig[16];
dig[16]<<=1;
dig[16]=(dig[16])|((t>>5) & 0x01);
// t=dig[17];
// dig[17]<<=1;
// dig[17]=(dig[17])|((tmp>>5) & 0x01);
// tmp=dig[18];
// dig[18]<<=1;
// dig[18]=(dig[18])|((t>>5) & 0x01);
void modu2(){
tmp=dig[0];
dig[0]<<=2;
t=dig[1];
dig[1]<<=2;
dig[1]=(dig[1])|((tmp>>4) & 0x03);
tmp=dig[2];
dig[2]<<=2;
dig[2]=(dig[2])|((t>>4)& 0x03);
t=dig[3];
dig[3]<<=2;
dig[3]=(dig[3])|((tmp>>4)& 0x03);
tmp=dig[4];
dig[4]<<=2;
dig[4]=(dig[4])|((t>>4)& 0x03);
t=dig[5];
dig[5]<<=2;
dig[5]=(dig[5])|((tmp>>4)& 0x03);
tmp=dig[6];
dig[6]<<=2;
dig[6]=(dig[6])|((t>>4) & 0x03);
t=dig[7];
dig[7]<<=2;
dig[7]=(dig[7])|((tmp>>4)& 0x03);
tmp=dig[8];
dig[8]<<=2;
dig[8]=(dig[8])|((t>>4)& 0x03);
t=dig[9];
dig[9]<<=2;
dig[9]=(dig[9])|((tmp>>4)& 0x03);
tmp=dig[10];
dig[10]<<=2;
dig[10]=(dig[10])|((t>>4) & 0x03);
t=dig[11];
dig[11]<<=2;
dig[11]=(dig[11])|((tmp>>4)& 0x03);
tmp=dig[12];
dig[12]<<=2;
dig[12]=(dig[12])|((t>>4)& 0x03);
t=dig[13];
dig[13]<<=2;
dig[13]=(dig[13])|((tmp>>4)& 0x03);
tmp=dig[14];
dig[14]<<=2;
dig[14]=(dig[14])|((t>>4) & 0x03);
t=dig[15];
dig[15]<<=2;
dig[15]=(dig[15])|((tmp>>4) & 0x03);
tmp=dig[16];
dig[16]<<=2;
dig[16]=(dig[16])|((t>>4) & 0x03);
// t=dig[17];
// dig[17]<<=2;
// dig[17]=(dig[17])|((tmp>>4) & 0x03);
// tmp=dig[18];
// dig[18]<<=2;
// dig[18]=(dig[18])|((t>>4) & 0x03);
void modu3(){
tmp=dig[0];
dig[0]<<=3;
t=dig[1];
dig[1]<<=3;
dig[1]=(dig[1])|((tmp>>3) & 0x07);
tmp=dig[2];
dig[2]<<=3;
dig[2]=(dig[2])|((t>>3)& 0x07);
t=dig[3];
dig[3]<<=3;
dig[3]=(dig[3])|((tmp>>3)& 0x07);
tmp=dig[4];
dig[4]<<=3;
dig[4]=(dig[4])|((t>>3)& 0x07);
t=dig[5];
dig[5]<<=3;
dig[5]=(dig[5])|((tmp>>3)& 0x07);
tmp=dig[6];
dig[6]<<=3;
dig[6]=(dig[6])|((t>>3) & 0x07);
t=dig[7];
dig[7]<<=3;
dig[7]=(dig[7])|((tmp>>3)& 0x07);
tmp=dig[8];
dig[8]<<=3;
dig[8]=(dig[8])|((t>>3)& 0x07);
t=dig[9];
dig[9]<<=3;
dig[9]=(dig[9])|((tmp>>3)& 0x07);
tmp=dig[10];
dig[10]<<=3;
dig[10]=(dig[10])|((t>>3) & 0x07);
t=dig[11];
dig[11]<<=3;
dig[11]=(dig[11])|((tmp>>3)& 0x07);
tmp=dig[12];
dig[12]<<=3;
dig[12]=(dig[12])|((t>>3)& 0x07);
t=dig[13];
dig[13]<<=3;
dig[13]=(dig[13])|((tmp>>3)& 0x07);
tmp=dig[14];
dig[14]<<=3;
dig[14]=(dig[14])|((t>>3) & 0x07);
t=dig[15];
dig[15]<<=3;
dig[15]=(dig[15])|((tmp>>3) & 0x07);
tmp=dig[16];
dig[16]<<=3;
dig[16]=(dig[16])|((t>>3) & 0x07);
// t=dig[17];
// dig[17]<<=3;
// dig[17]=(dig[17])|((tmp>>3) & 0x07);
// tmp=dig[18];
// dig[18]<<=3;
// dig[18]=(dig[18])|((t>>3) & 0x07);
void modu4(){
tmp=dig[0];
dig[0]<<=4;
t=dig[1];
dig[1]<<=4;
dig[1]=(dig[1])|((tmp>>2) & 0x0f);
tmp=dig[2];
dig[2]<<=4;
dig[2]=(dig[2])|((t>>2)& 0x0f);
t=dig[3];
dig[3]<<=4;
dig[3]=(dig[3])|((tmp>>2)& 0x0f);
tmp=dig[4];
dig[4]<<=4;
dig[4]=(dig[4])|((t>>2)& 0x0f);
t=dig[5];
dig[5]<<=4;
dig[5]=(dig[5])|((tmp>>2)& 0x0f);
tmp=dig[6];
dig[6]<<=4;
dig[6]=(dig[6])|((t>>2) & 0x0f);
t=dig[7];
dig[7]<<=4;
dig[7]=(dig[7])|((tmp>>2)& 0x0f);
tmp=dig[8];
dig[8]<<=4;
dig[8]=(dig[8])|((t>>2)& 0x0f);
t=dig[9];
dig[9]<<=4;
dig[9]=(dig[9])|((tmp>>2)& 0x0f);
tmp=dig[10];
dig[10]<<=4;
dig[10]=(dig[10])|((t>>2) & 0x0f);
t=dig[11];
dig[11]<<=4;
dig[11]=(dig[11])|((tmp>>2)& 0x0f);
tmp=dig[12];
dig[12]<<=4;
dig[12]=(dig[12])|((t>>2)& 0x0f);
t=dig[13];
dig[13]<<=4;
dig[13]=(dig[13])|((tmp>>2)& 0x0f);
tmp=dig[14];
dig[14]<<=4;
dig[14]=(dig[14])|((t>>2) & 0x0f);
t=dig[15];
dig[15]<<=4;
dig[15]=(dig[15])|((tmp>>2) & 0x0f);
tmp=dig[16];
dig[16]<<=4;
dig[16]=(dig[16])|((t>>2) & 0x0f);
// t=dig[17];
// dig[17]<<=4;
// dig[17]=(dig[17])|((tmp>>2) & 0x0f);
// tmp=dig[18];
// dig[18]<<=4;
// dig[18]=(dig[18])|((t>>2) & 0x0f);
void modu5(){
tmp=dig[0];
dig[0]<<=5;
t=dig[1];
dig[1]<<=5;
dig[1]=(dig[1])|((tmp>>1) & 0x1f);
tmp=dig[2];
dig[2]<<=5;
dig[2]=(dig[2])|((t>>1)& 0x1f);
t=dig[3];
dig[3]<<=5;
dig[3]=(dig[3])|((tmp>>1)& 0x1f);
tmp=dig[4];
dig[4]<<=5;
dig[4]=(dig[4])|((t>>1)& 0x1f);
t=dig[5];
dig[5]<<=5;
dig[5]=(dig[5])|((tmp>>1)& 0x1f);
tmp=dig[6];
dig[6]<<=5;
dig[6]=(dig[6])|((t>>1) & 0x1f);
t=dig[7];
dig[7]<<=5;
dig[7]=(dig[7])|((tmp>>1)& 0x1f);
tmp=dig[8];
dig[8]<<=5;
dig[8]=(dig[8])|((t>>1)& 0x1f);
t=dig[9];
dig[9]<<=5;
dig[9]=(dig[9])|((tmp>>1)& 0x1f);
tmp=dig[10];
dig[10]<<=5;
dig[10]=(dig[10])|((t>>1) & 0x1f);
t=dig[11];
dig[11]<<=5;
dig[11]=(dig[11])|((tmp>>1)& 0x1f);
tmp=dig[12];
dig[12]<<=5;
dig[12]=(dig[12])|((t>>1)& 0x1f);
t=dig[13];
dig[13]<<=5;
dig[13]=(dig[13])|((tmp>>1)& 0x1f);
tmp=dig[14];
dig[14]<<=5;
dig[14]=(dig[14])|((t>>1) & 0x1f);
t=dig[15];
dig[15]<<=5;
dig[15]=(dig[15])|((tmp>>1) & 0x1f);
tmp=dig[16];
dig[16]<<=5;
dig[16]=(dig[16])|((t>>1) & 0x1f);
// t=dig[17];
// dig[17]<<=5;
// dig[17]=(dig[17])|((tmp>>1) & 0x1f);
// tmp=dig[18];
// dig[18]<<=5;
// dig[18]=(dig[18])|((t>>1) & 0x1f);
sir i need asm file this is written in c
; P2 DISPLAY DATA 8 BIT
; P3.0 SERIAL DATA
; P3.1 SHIFT CLK
; P3.2 STORE CLK
; P3.3 M CLEAR
; here 595 sh reg are use and delay set according to your hw xtal
DIS_BUS EQU P2
DATA_BIT BIT P3.0
CLK BIT P3.2
STCLK BIT P3.1
RESET BIT P3.3
ORG 000H
LJMP 0020H
ORG 0020H
KKKKK: MOV SP,#040H
MOV P3,#00000000B
CLR DATA_BIT
PSS:
MOV R5,#00h
MOV DPTR,#0300H
MOV R4,#095H
MOV R5,#002h
;******************************************3/4
AA:
NEXT: MOV R3,#010
;******************************************2
LOOP: LCALL RESET_ALL
LCALL PULES
MOV R1,#00H
MOV R0,#00H
;******************************************1
CONTINUE: LCALL APULES
MOV A,R1
MOVC A,@A+DPTR
CPL A
MOV DIS_BUS,A
INC R1
ACALL Dlay5
MOV DIS_BUS,#0FFH
NOP
CJNE R1,#48,CONTINUE
DJNZ R3,LOOP
INC DPTR
DJNZ R4,NEXT
INC DPTR
DJNZ R5,AA
;******************************************4
SJMP PSS
;******************************************5
APULES:
SETB CLK
NOP
CLR CLK
NOP
SETB STCLK
NOP
CLR STCLK
RET
PULES:
SETB DATA_BIT
NOP
SETB CLK
NOP
NOP
CLR CLK
NOP
CLR DATA_BIT
SETB STCLK
NOP
CLR STCLK
RET
RESET_ALL: CLR RESET
NOP
SETB RESET
RET
DLAY5: ; Use R6 and R7 to Delay 5 msecs
MOV R7,#03
DLAY5LOOP: MOV R6,#03
DLAY5LOOP1: DJNZ R6,DLAY5LOOP1
DJNZ R7,DLAY5LOOP
RET
ORG 0300h
DB 00H,00H,00H,00H,00H,00H,00H,00H,00H,00H
; from onwards you can fill msg like below
DB 0FEH,0FFH,03H,06H,0CH,1CH,0CH,06H,03H,0FFH,0FEH ;W
END
---------- Post added at 00:24 ---------- Previous post was at 00:23 ----------
you have to change circuit and few components now
i need a little of explanation about the code ,can u pls help me ,the one in c lang.
