lil_vinn
Newbie level 5
I need a schematic made for a homemade project. Currently I have a power supply (AC to DC converter; on the actual converter it says its a 15v 3.3A, but the sheet that came with it said its voltage outage is 12.6V DC, current output 3A, 30W.) And a heating element that when connected is at 350 degrees C. I need a circuit/schematic that uses a vibration sensor and when a vibration is sensed the heating element needs to be at 350 degrees celcius but when a vibration is not sensed it needs to be at 290 degrees.
I have a heating element running at 350degs C with 12.6 V on it. To get it to run at 290 degs, I must dissipate 290/350 less watts in the heating element. But the power is proportional to V^2, so if v is the new voltage then v^2/12.6^2 = 290/350, doing the maths v = 11.46 Volts. So if I need to put a small resistance in the circuit to drop the voltage to main heating element to 11.46 volts then its temperature will fall accordingly. I need to use to vibration detector to short out this resistor then the main heating element will go back to its correct temperature. My vibration detector will not handle very much current, so I need to use a relay and connect the vibration detector to one side of the relay coils, the other side to + or - of the 12 Volts as applicable and use the relay contacts to do the actual current switching. So I will need a 12V relay with contacts that can switch greater then 3A.
I hope this is enough information its fairly simple however I don't know how to make a schematic to meet what I want.
Thanks,
Justin
Thanks,
Justin
