laoadam
Member level 2
The sender send NEC date, but the receiver got UNKNOWN, why?
receiver (pin2) code:
#include <Arduino.h>
sender (pin3) code:
Define macros for input and output pin etc.
#elif defined(__AVR__) // Default as for ATmega328 like on Uno, Nano etc.
#define IR_RECEIVE_PIN 2 // To be compatible with interrupt example, pin 2 is chosen here.
#define IR_SEND_PIN 3
///// #include "PinDefinitionsAndMore.h"
///// #elif defined(__AVR__) // Default as for ATmega328 like on Uno, Nano etc.
#define TONE_PIN 4
#define APPLICATION_PIN 5
#define ALTERNATIVE_IR_FEEDBACK_LED_PIN 6 // E.g. used for examples which use LED_BUILDIN for example output.
#define _IR_TIMING_TEST_PIN 7
#include <IRremote.hpp>
#define DELAY_AFTER_SEND 2000
#define DELAY_AFTER_LOOP 5000
int button = 8;
void setup() {
Serial.begin(115200);
Serial.print("T_gd_setup!");
Serial.print("File : "), Serial.println(__FILE__);
Serial.print("Date : "), Serial.println(__DATE__);
Print internal signal generation info
IrSender.enableIROut(38); // Call it with 38 kHz to initialize the values printed below
Serial.print(F("Send signal mark duration is "));
Serial.print(IrSender.periodOnTimeMicros);
Serial.print(F(" us, pulse correction is "));
Serial.print(IrSender.getPulseCorrectionNanos());
Serial.print(F(" ns, total period is "));
Serial.print(IrSender.periodTimeMicros);
Serial.println(F(" us"));
pinMode(button, INPUT);
uint16_t sAddress = 0x0102; ////// A remote control that is programmed with device address 4E.24 can only control the digital signage display that is
/////// also programmed with device address 4E.24.
uint8_t sCommand = 0x34; //// NEC command (HEX) 0x34 = Fast Backward, DEC 52,
uint8_t sRepeats = 0;
void loop() {
Print values
Serial.println();
Serial.print(F("address=0x"));
Serial.print(sAddress, HEX);
Serial.print(F(" command=0x"));
Serial.print(sCommand, HEX);
Serial.print(F(" repeats="));
Serial.println(sRepeats);
Serial.println();
Serial.println();
Serial.flush();
if (digitalRead(button) == HIGH) {
Serial.println(F("Send NEC with 8 bit address"));
Serial.flush();
IrSender.sendNEC(sAddress & 0xFF, sCommand, sRepeats);
delay(DELAY_AFTER_SEND); // delay must be greater than 5 ms (RECORD_GAP_MICROS), otherwise the receiver sees it as one long signal
Serial.println(F("Send NEC with 16 bit address"));
Serial.flush();
IrSender.sendNEC(sAddress, sCommand, sRepeats);
#include <IRremote.h>
const int RECV_PIN = 2;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
irrecv.blink13(true);
void loop() {
if (irrecv.decode()) {
if (results.decode_type == NEC) {
Serial.print("NEC: ");
} else if (results.decode_type == SONY) {
Serial.print("SONY: ");
} else if (results.decode_type == RC5) {
Serial.print("RC5: ");
} else if (results.decode_type == RC6) {
Serial.print("RC6: ");
} else if (results.decode_type == UNKNOWN) {
Serial.print("UNKNOWN: ");
Serial.println(results.value, HEX);
irrecv.resume(); // Receive the next value
