waytronic
Newbie level 3
Music module--MP3 MODULES WITH BUITI-IN MEMORY, musical voice modulator
Features
* Support 8Kbps ~ 320Kbps bit-rate, MP3 format audio files
* Stereo audio output.
* Control interface: key, DSA .
* Support to play exact mp3 file in the folder by MCU control
* Built in NAND-Flash as memory for long duration playing.
* Operating voltage: DC5V.
* Chipset solution is available
Advantages
* Built-in NAND FLASH. This is other MP3 modules are not available in market.
the biggest advantages of built-in FLASH(compared with SD card) is: remove
mechanical contact, not loosen, without cards'compatibility issues. Therefore,
suitable for vibration products in industries or field.
* With hidden music capabilities. contents in SD card easy to be copy by other
companies. but this module, it has hidden zone and public zone. music files be
programed by us at first, then put into the hidden zone, so the end-users can
not copy the files, even format can not delete. Is a unique function. While
the music which clients normal useb can be downloaded by USB directly.
* With serial interface control mode, which is not available in other modules.
It is trasffer any section of voice/ music/ song in the FLASH.
Applications
Home appliances, such as intelligent navigation of refrigerators, air conditioners, induction cooker and so on, as well as advanced toys, automotive electronic systems, long time playback systems require, etc.
Features
Advantages
Applications
