Multisim Question. Why it displays Ic (uA) as V (mA)?
Bangalore, India
Multisim Question. Why it displays Ic (uA) as V (mV)?
I am trying to simulate BJT CE output characteristics using Multisim. The problem is in the simulation graph the Ic (uA) is shown as V (mV). Why? How to make it show Ic (uA) for the
y - axis?
The plot of values are ok and it shows Vce for x - axis but problem is y - axis label. I am attaching multisim file.
  • 2n2222a ce oc.rar
You can edit the labels by double clicking it.
I know that I can edit the label but it only changes the label. The y-axis values 0 m, 3 m, 5 m, etc... doesn't change. It has to display 0 uA, 10uA, 20uA, ... 50uA.
This is from one of the examples. Y-axis will show Ic(mA) against Vce(V) for different (steps) of base currents.
It is a bug of Multisim. I eneterd range as 10 nA to 50 nA and it shows as uA. I hope NI will fix the bug. The values displayed are wrong. For 10 uA to 50 uA (entered as 10 nA to 50 nA) it shows upto 10 uA the whole range.
Is the auto axis scaling feature enabled?
Normally under "Graph - Properties - Axis" Click "Auto-range" and see if it makes a difference.
Oops. There was a mistake. The values 10 uA, 20 uA, ... 50uA are base currents which are not plotted. Actually the graph is right. It is plotting Ic vs Vce. Ic is 0 to 10 uA. The only problem is nA = uA and uA = mA in Multisim. It is the only bug. I tried Auto Range. It did not make any difference. Anyways the second graph I posted it right. Ic varies for -3 to 10 uA on the graph.
Maybe mA is right. I will calculate theoritically looking at the datasheet. I think Ic will be in mA when Ib is in uA.
Yes. It is mA. Ic is in mA. Multisim is right.
