Multi Plug Socket connection diagram
Fazlay Rabbi
Junior Member level 1
I need to bulild a multi plug socket (220v Ac ) for my pc connection .I know that i need to connect them in parallel .But as it need to be perfect otherwise a huge damage will happen that makes me confused .So I need to ensure the connection . If any one have any schemetic diagram or any tutorial like that please provide . It may have 5/6 ports.
I think it would be good if you can buy a factory made power cord as trying to build one will probably cost you more money. Also proper care should be taken to isolate each plug base and a good enclosure should be used as well. Otherwise you may end up with a short circuit and burn down your room. Electricity is hazardous.
