[Moved] what is the use of Electronic oscillator
Nipuna56
what is the use of Electronic oscillator?
why it use with caps?
what it gives us when we use higher value oscilator
An electronic oscillator is an electronic circuit that produces a repetitive, oscillating electronic signal, often a sine wave or a square wave. Oscillators convert direct current (DC) from a power supply to an alternating current signal. They are widely used in many electronic devices. Common examples of signals generated by oscillators include signals broadcast by radio and television transmitters, clock signals that regulate computers and quartz clocks, and the sounds produced by electronic beepers and video games. In short oscillators are used for tuning the desired frequency from several range of frequency.
* In an RC oscillator circuit, the filter is a network of resistors and capacitors. RC oscillators are mostly used to generate lower frequencies, for example in the audio range. Common types of RC oscillator circuits are the phase shift oscillator and the Wien bridge oscillator.
* In an LC oscillator circuit, the filter is a tuned circuit (often called a tank circuit) consisting of an inductor (L) and capacitor (C) connected together. Charge flows back and forth between the capacitor's plates through the inductor, so the tuned circuit can store electrical energy oscillating at its resonant frequency.
