photossta
Newbie level 1
Please I am new to SCADA system and currently doing a specification document for my university project. I am doing it for a SCADA system and need someone with knowledge to review what terms I have used for the sections I have.
For the System Operational Functional Requirements section, I wrote
Fire System Requirements
The SCADA system will perform monitoring of the Fire Main Inlet Valve. The following status of the Inlet Valve will be monitored, logged and displayed by the ITCS:
• Inlet Valve Position
• Inlet Valve state (Open / Close)
• Inlet Valve Local Control state
• Inlet Valve Fault(Neither Open or Closed)
• Pressure Switch
• Flow Switch
The SCADA system will perform control of the Fire Main Inlet Valve. The Inlet Valve signals to be driven are as follows:
• Inlet Valve Open Drive
• Inlet Valve Close Drive
For the System Input and Output Requirements section, I wrote
The SCADA system I/O with the Fire System will allow:
1) Alarm and status information of the system to be monitored, logged and displayed at the SCADA Clients including:
a) Inlet valve position;
b) Inlet valve alarms;
c) Inlet valve status;
d) Pressure switch status;
e) Flow switch status.
2) Control of the system by operators at the SCADA Client including:
Please I would appreciate if someone could help and evaluate the terms I have used such as 'Status', 'Position' 'State' and others and to correct me if I wrote it wrong or if there are better terms to use or better ways to structure my information.
• Pressure Switch
• Flow Switch
