czabhinav
Newbie level 5
I have a circuit where I am using a SIM900 GSM/GPRS module. As per the datasheet it needs 3.4 V - 4.8 V and upto 2 A of current. I am using LM2576. The input to the regulator is 12 V & 4.2 A and output (which is going to SIM900) is 4.175 V. I have connected leds for NETLIGHT and STATUS LIGHT. I have connected a switch between PWRKEY and GND to start the SIM900. Following is the schematic of regulator:
![1.PNG 1.PNG](https://www.edaboard.com/data/attachments/67/67126-b2282cf73281d88e5741b8f808813cf9.jpg)
SIM900:
![2.PNG 2.PNG](https://www.edaboard.com/data/attachments/67/67127-1efa2a93e6d6aec1cfb7b28b551ff383.jpg)
The problem I am facing is as soon as I press the switch S1 to turn on the SIM900, its netlight led starts blinking and status light led is always off. There is no high voltage on status pin. I know that the net light blinks for network registration but this kind of blinking is not the expected behaviour of net light. It blinks twice a second and when I release the switch, it stops blinking. Status pin is always low. I checked the voltage. voltage seems to be stable on VBAT pins. Initially I am giving it 4.175v and when I press the switch it becomes 4.15-4.17v. I tried reflashing the firmware but during the process, it shows following error
![error.PNG error.PNG](https://www.edaboard.com/data/attachments/67/67128-da1be7998f1f3734c1e95d2f2c24f054.jpg)
In above pic it says that Target responding.. Does this means the SIM900A is in working condition because I was thinking that SIM900A is faulty.
What else could be the reason for this kind of behaviour. How can I debug it.
Please help. Thanks
SIM900:
Please help. Thanks
