[MOVED] Reading binary data over the serial port
isamel85
Newbie level 6
Hello
In fact, I want to acquire a 8-bit binary data on serial port using Matlab (eg 00001100 in binary or 12 decimal). I make a test loop back just sending that data over the port and receive on the same port, knowing that sending code works fine and I checked it by HyperTerminal.
I tried this code for the acquisition in Matlab script:
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
s=serial('COM1'); % Create a serial port object
%Configure property values
s.InputBufferSize=50000;
s.BaudRate=9600;
fopen(s); %open the port
% Here the beginning of the reading binary data -----------------------------------------------------------
index = 1;
nb_bytes = get(s,'BytesAvailable');
while (index < get(s,'inputBuffersize'))
if nb_bytes
out= fread(s, nb_bytes,'uint8');
index = index + nb_bytes;
end;
pause(0.2);
end;
%End of reading code-------------------------------------------------------------------------------------------
%Disconnect and clean up
fclose(s);
delete(s);
clear s;
But I get nothing. Maybe the code missed something.
Please can someone help me to solve this problem?
Thanks in advance for any help.
Best regards,
Isamel
Re: Reading binary data over the serial port
I don't see anywhere where you send data to the serial port. If you are in loopback test, you should send the data from the same port. Somewhere after fopen, try send data on serial port and check for 'ByteAvailable' on the port.
If the data was sent previously by an other application. See the comment about ByteAvailable from Matlab.
"BytesAvailable indicates the number of bytes currently available to be read from the input buffer. The property value is continuously updated as the input buffer is filled, and is set to 0 after the fopen function is issued."
it seems that after a fopen, the input buffer is flushed.
The last code missed the writing data; I put only the opening and closing of the port and the reception of the data; now you can check the entire code:
s.OutputBufferSize=50000;
s.BaudRate=9600;
%flush the input buffer
flushinput(s);
pause(0.01);
% Here the beginning of the sending binary data -----------------------------------------------------------
binary_data_in_8bits=00001100;%12 in decimal
decimal_data=bin2dec(binary_data_in_8bits)% conversion of the data from binary to decimal
fwrite(s,decimal_data,'uint8','async');
%End of sending code-------------------------------------------------------------------------------------
index = 1;
if nb_bytes
end;
pause(0.2);
end;
fclose(s);
delete(s);
clear s;
Please help me to solve this problem?
Thanks in advance for your help.
Best regards,
Isamel
I guess that the while loop cause the problem. nb_bytes should be 1 and you will execute the loop 'inputBuffersize' time. Out will be overwritten on each loop.
Remove your while loop for a test and check what you get.
Also add a pause after the fwrite to let the serial port do its job. Try stepping your code to see where is the problem.
Good luck
Basically do standard debugging steps. In this case, something like: Get known to work example serial script from your favorite matlab example script repository. Pay attention to the fact that serial communication example will be different for windows vs linux. Verify that example works. Use working example as template/inspiration for your code.
