midou999
Newbie level 2
please , i want to program AD75019 , an analogue Cross point Switch from analogue devices 16x16, with FPGA, ad75019 have a serial interface, i'have to shift 256 bit into 256 bit shift register , once the register is full i apply a PCLK pulse to to transfer the register to latch (like it's mentionned in the datasheet) my problem is, that i can'T close or open any switch
please , anyone could help, thanks in Advance
this my configuration:
VDD:11V
VCC:5V
VSS: 0V
SCLK: 1MHZ
this how i did the spi interface : a shift register of 256 bit with a state machine for controlling PCLK signal:
-- spi_SM.vhd
VDD:11V
VCC:5V
VSS: 0V
SCLK: 1MHZ
-- spi_SM.vhd
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_signed.all; use ieee.std_logic_arith.all; entity spi_SM is generic(N:integer :=256; C:integer :=9; D:integer :=4 ); -- generic(C:integer :=9); port( clk :in std_logic; rst_n:in std_logic; data: in std_logic_vector (N-1 downto 0); SCLK: inout std_logic; --inout pour qu'il peut etre lu en process SIN ut std_logic; PCLK: out std_logic ); end spi_SM; architecture rtl of spi_SM is type States is (ACTIF, UPDATE, IDLE); signal state : States := ACTIF; signal EndSend : std_logic_vector(8 downto 0); signal t_rst_cnt_n : std_logic ; --Diviseur (pour generer la frequence d'horloge du port SPI(20Khz-5Mhz)) component diviseur generic ( N : integer := 4 ); port( clk : in std_logic ; rst_n : in std_logic ; clk_out : out std_logic ); end component; --Compteurnbit component Compteurnbit generic ( N : integer := 16 ); port( clk : in std_logic ; rst_cnt_n : in std_logic ; OutCount : inout std_logic_vector(N-1 downto 0) ); end component; --Sregister component Sregister generic ( N : integer := 256 ); port( clk : in std_logic; rst_n : in std_logic; S :in std_logic_vector (N-1 downto 0);-- durée de train d'impulsion Q : out std_logic ); end component; begin U0_diviseur : diviseur generic map(D) port map(clk, rst_n, SCLK); ---definir frequence de SPI (clk de base=20 Mhz) U0_Sregister : Sregister generic map(N) port map(SCLK,rst_n,data,SIN); U0_Compteurnbit : Compteurnbit generic map(C) port map(SCLK,t_rst_cnt_n,EndSend);-- counting 256 pulse to set EndSend send : process (SCLK,EndSend) begin if (rst_n='0') then t_rst_cnt_n<='0'; else case state is when actif=> if (unsigned(EndSend) = 256) then -- opertation arithmetique donc convertit std_logic_vector en unsigned PCLK<='0';--0 t_rst_cnt_n<='0'; state<= UPDATE; else t_rst_cnt_n<='1'; PCLK<='1'; state<= ACTIF; end if; when UPDATE=> PCLK<='1';--0 -- state<= actif ; state<= IDLE; when IDLE=> PCLK<='1'; state<= IDLE; end case; end if; end process; end;
