[Moved] Programming AD75019 with FPGA
midou999
Newbie level 2
Hello,
please , i want to program AD75019 , an analogue Cross point Switch from analogue devices 16x16, with FPGA, ad75019 have a serial interface, i'have to shift 256 bit into 256 bit shift register , once the register is full i apply a PCLK pulse to to transfer the register to latch (like it's mentionned in the datasheet) my problem is, that i can'T close or open any switch
please , anyone could help, thanks in Advance
this my configuration:
VDD:11V
VCC:5V
VSS: 0V
SCLK: 1MHZ
this how i did the spi interface : a shift register of 256 bit with a state machine for controlling PCLK signal:
-- spi_SM.vhd
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_signed.all;
entity spi_SM is
generic(N:integer :=256; C:integer :=9; D:integer :=4 );
-- generic(C:integer :=9);
port(
clk :in std_logic;
rst_n:in std_logic;
data: in std_logic_vector (N-1 downto 0);
SCLK: inout std_logic; --inout pour qu'il peut etre lu en process
SIN ut std_logic;
PCLK: out std_logic
end spi_SM;
architecture rtl of spi_SM is
type States is (ACTIF, UPDATE, IDLE);
signal state : States := ACTIF;
signal EndSend : std_logic_vector(8 downto 0);
signal t_rst_cnt_n : std_logic ;
--Diviseur (pour generer la frequence d'horloge du port SPI(20Khz-5Mhz))
component diviseur
generic ( N : integer := 4 );
port(
clk : in std_logic ;
rst_n : in std_logic ;
clk_out : out std_logic
end component;
--Compteurnbit
component Compteurnbit
generic ( N : integer := 16 );
port(
rst_cnt_n : in std_logic ;
OutCount : inout std_logic_vector(N-1 downto 0)
end component;
--Sregister
component Sregister
generic ( N : integer := 256 );
port(
clk : in std_logic;
rst_n : in std_logic;
S :in std_logic_vector (N-1 downto 0);-- durée de train d'impulsion
Q : out std_logic
end component;
begin
U0_diviseur : diviseur generic map(D) port map(clk, rst_n, SCLK); ---definir frequence de SPI (clk de base=20 Mhz)
U0_Sregister : Sregister generic map(N) port map(SCLK,rst_n,data,SIN);
U0_Compteurnbit : Compteurnbit generic map(C) port map(SCLK,t_rst_cnt_n,EndSend);-- counting 256 pulse to set EndSend
send : process (SCLK,EndSend)
begin
if (rst_n='0') then
t_rst_cnt_n<='0';
else
case state is
when
actif=>
if (unsigned(EndSend) = 256) then -- opertation arithmetique donc convertit std_logic_vector en unsigned
PCLK<='0';--0
t_rst_cnt_n<='0';
state<= UPDATE;
else
t_rst_cnt_n<='1';
PCLK<='1';
state<= ACTIF;
end if;
when UPDATE=>
PCLK<='1';--0
-- state<= actif ;
state<= IDLE;
when IDLE=>
PCLK<='1';
state<= IDLE;
end case;
end if;
end process;
end;
Re: programming AD75019 with FPGA
Important details are hidden in the design, the shift register is e.g. missing a paralle load signal, I wonder how it's working at all. Personally I would prefer to see trivial functions like this in the behavioral code to be able to check their operation.
Generally, you should check the waveforms generated by your design either in a simulation or in hardware with SignalTap/Chipscope and compare with the datasheet requirements.
You should either define SCLK as buffer type or copy an internal alias signal to the output port, to be able to read it back in the design. Inout has a different purpose.
P.S.: Positional association in component instantiation is generally fault-prone. I really suggest to use named association, also to improve code readability.
