CAMALEAO
Full Member level 4
Hi guys,
Has anyone used prof. Murmann gm/id start kit?
I don't understand point 3) As a next step, you will probably want to create mat files for your own technology. For that purpose, you can use either "techsweep_hspice.m" or "techsweep_spectre.m," depending on which simulator you want to use. The scripts rely on a config file that sets the relevant paths, file names, transistor instantiation, etc. Three example config files are provided (edit these appropriately according to your setup).
What does he mean? Do I need to put in the path section, the path to my models files?
Regards.
Regards.
