[MOVED] Operational amplifiers and diodes
portuguese
Newbie level 6
Newbie level 6
Hi guys! I'm portuguese and I have an Electricity exam tomorrow. So this is really urgent. There are 2 kinds of exercises I don't know how to do. The tests usually have similar exercises to these ones:
1) Operational Amplifiers
Consider the circuit represented in this picture:
. The voltage vi(t)=1sin(wt) V and the operational amplifier saturates in (+-)12V. Calculate and plot the signal of the voltage vo(t).
2) Diodes
Consider this circuit:
. Plot the signal vo(t) (show your calculations [all of them]).
I really need your help! Thanks a lot!
Re: Operational amplifiers and diodes
2. Diodes
step by step circuit diagram... :grin:
See the attached diagram, replace vi(t)=1sin(wt) V
http://en.wikipedia.org/wiki/Operational_amplifier_applications
See also the graphical representation:
Thanks a lot! I understood the graphics really really well...
I have an additional question. Imagine they ask me in 2.) Diodes to find the Peak Inverse Voltage in diode D. Do you know how to calculate?
Thanks again!
Peak Inverse Voltage in diode D = -10V
Vg = -10V
Vg = i *1K + Ud + i * 1K
but
i=0
Vg = Ud
> Ud = -10V
Is it PIV=Initial voltage*Vout(from the voltage divider)? May I do that to every similar exercises?
PIV= Peak Inverse Voltage?
See details in the attached picture. Use KVL.
To be more precise, the complete formula for the peak reverse voltage:
Vg = i1 *R1 + Ud + i2*R2
but
R1=1k
R2=1k
i1= i2= 0
Vg= Ud
Yes, PIV = Peak Inverse Voltage.
Imagine this circuit:
Can I do the same thing to calculate the PIV?
Use KVL/KCL
Vg = i3R3 + Vd + i1 R1
Vg= i2R2 + Vz+ i1R1
I3=0, I1=i2
Vz= 0.7V, Vg= 10V
Vd= i2R2 + Vz
But
I2 = [10 -0.7]/(R1+R2)= 9.3/(R1+R2)
So
Vd = 9.3 R2 /(R1+R2) + 0.7V
