milan.rajik
Banned
How can I build a Inverter circuit for this module?
Here are the documents. They are in Chinese. I don't understand Chinese and they are PDF files. It will be helpful if someone can translate these to English
EGS002 是一款专门用于单相纯正弦波逆变器的驱动板。采用单相纯正弦波逆变器专用芯片EG8010 为控
制芯片,驱动芯片采用IR2110S。驱动板上集成了电压、电流、温度保护功能,LED 告警显示功能及风扇控
制功能,并可通过跳线设置50/60Hz 输出,软启动功能及死区大小。EGS002 为EGS001 改进版,兼容原本的
EGS001 接口,在原有的电路上增加了驱动电平闭锁功能,大大增强了板子的抗干扰能力。并增加了液晶显
示接口,方便用户使用芯片自带的显示功能。
EGS002 driver board is a dedicated single-phase pure sine wave inverter. Single-phase pure sine wave inverter is controlled ASIC EG8010 System chip, driver chip IR2110S.
Driver board integrates with voltage, current, temperature protection, LED alarm display and fan control System functions, and can be set via jumpers 50/60Hz output, soft-start function and the size of the dead zone.
EGS002 is an improved version of EGS001, and it is compatible with the original EGS001 interface on the original circuit has added the drive level locking function, which greatly enhances the board's anti-interference capability. And added the liquid crystal display connection. Making interfacing to LCD display chip more user-friendly.
