[moved] GSM commander - Automation and Control
PolygonTechnologies
Newbie level 1
https://gsmcommander.com
The GSM Commander is essentially a mini PLC with GSM Functionality. It is a fully programmable device that can be programmed to control and manage your equipment directly. Switching a pump via SMS? We can do that automatically via built in time functions. In addition we can check the pressure and flow rates.
This allows for endless possibilities & applications:
Cable Theft Prevention
Pumps and Irrigation
Water Treatment
Refrigeration
Temperature monitoring
One example is that the GSM Commander can be used for temperature monitoring. You would be able to monitor up to 11 temperature zones with a single system provided they are within 50m from the GSM Commander. Not only can you monitor temperature you can control it too.
What can the Commander provide:
You can access the temperature reading at any given time via our AirDrive Platform, please visit www.airdrive.co.za
Send an SMS to your cellphone when the temperature rises above or below a siongle or multiple set points.
You can log the temperatures to a platform at a specified interval, as well as on a critical event.
The Commander also has a built in functionality which reports power failures and power restores. Multiple users can be SMSed when either event occurs.
If you have a unique application for a SMS based monitoring and control system please feel free to contact us, with the GSM Commander the sky is the limit.
