Lokesh Waran
Junior Member level 1
While i am implementing the below verilog codings in CPLD -XC9572XL device the following error has been occurred .can anyone suggest me wat can we do for implement the same kind of various processes module codings (like phase locked loop,timer,automation purpose module) in single CPLD device, i know there is not enough space to fuse below coding due to less macrocell (72 macrocell) can any one suggest me which xilinx device is opt for this process either CPLD or FPGA ? I AM USING THIS FRO INDUSTRIAL AUTOMATION PURPOSE.THANK YOU
ERROR:Cpld:837 - Insufficient number of macrocells. The design needs at least 95
but only 72 left after allocating other resources.
ERROR:Cpld:868 - Cannot fit the design into any of the specified devices with
the selected implementation options.
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 module pwm_cpld(clk,sw1,sw2,pulse,dc_out,a); //input ports input clk; input sw1,sw2; //output ports output pulse; output dc_out; output [3:0]a; //............................................ //internal variables reg pulse ; reg[12:0]cnt1=200; reg[7:0]cnt=10; reg[12:0]h; reg[20:0]f; always @(posedge clk) begin h<=h+1; if (h<cnt1) pulse <=1'b1; else if ((h>cnt1) && (h < 2000)) pulse <= 1'b0; else if (h>2000) h<=0; end always @ (posedge clk) begin if (sw1==1'b0) begin f<=f+1; if(f>1000000) begin cnt<=cnt+1; f <=0; end if(cnt>=90) cnt<=90; end //................................................................ if (sw2==1'b0) begin f<=f+1; if (f>1000000) begin cnt<=cnt-1; f <= 0; end if (cnt<= 10) cnt<=10; end cnt1<=cnt*20; end assign a =4'b0111; assign dc_out =1'b0; endmodule
