[moved] Create Scematic greyed out in Degin Vision
Damomeera
Junior Member level 3
Coimbatore
Hi All,
I have written behavioral coding for ALU. While creating schematic in design vision, the icon gets greyed out after compiling my design. Please help me with this problem.
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
`timescale 1ns / 1ps
module aluuu(
    a,
    b,
    status_in,
    op,
    clk,
     rst,
    status_out,
//c0 is the Output bits for all operations. For Mul operations, output is {c1,c0}
//as multiplication of two 16 bit number resuts in maximum of 32 bit number.
    c0,
    c1
     input [15:0] a,b;
     input [3:0] status_in;
     input [3:0] op;
     input clk,rst;
     output [15:0] c0;
     output [15:0] c1;
     output [3:0] status_out;
    reg [3:0] status_out;
// status register in test_bench - 0:Carry bit 1:Zero bit 2:Borrow bit 3:Parity bit
    reg [15:0] c0,c1;
//Opcode written as parameters.
    parameter
    Add=4'b0000,
    Adc=4'b0001,
    Sub=4'b0010,
    Sbb=4'b0011,
    inc=4'b0100,
    dec=4'b0101,
    Mul=4'b0110,
    pst=4'b0111,
    And=4'b1000,
    Or =4'b1001,
    Not=4'b1010,
    Nan=4'b1011,
    Nor=4'b1100,
    Xor=4'b1101,
    Lst=4'b1110,
    Rst=4'b1111;
function parity;
input [15:0] c;
begin
parity=0;
if(status_in[3]==0) begin
    parity = (status_in[3]^c0[0]^c0[1]^c0[2]^c0[3]^c0[4]^c0[5]^c0[6]^c0[7]^c0[8]^c0[9]^c0[10]^c0[11]^c0[12]^c0[13]^c0[14]^c0[15]);
end
else begin
    parity = (c0[0]^c0[1]^c0[2]^c0[3]^c0[4]^c0[5]^c0[6]^c0[7]^c0[8]^c0[9]^c0[10]^c0[11]^c0[12]^c0[13]^c0[14]^c0[15]);
end
end
endfunction
function zero_check;
input [15:0]x,y;
begin
zero_check=0;
if(x==0 && y ==0) begin zero_check= status_in[1] | 1; end
else begin zero_check=status_in[1] & 0; end
end
endfunction
//Beginning of the always block.
    always@(posedge clk) begin
        if(rst) begin
            c0=0;
            c1=0;
            status_out = status_in;
        end
        else begin
            case(op)
                Add:begin{status_out[0],c0} = a+b; c1=0; status_out[3]=parity(c0);
            status_out[1]=zero_check(c0,c1);end
                Adc:begin {status_out[0],c0} = a+b+status_in[0]; c1=0; status_out[3]=parity(c0);
                Sub:begin c0 = a-b;c1=0;status_out[3]=parity(c0);
            status_out[1]=zero_check(c0,c1);if(b>a)begin status_out[2]=1; end else begin status_out[2]=0; end end
                Sbb:begin c0 = a-b-status_in[2]; c1=0;status_out[3]=parity(c0);
            status_out[1]=zero_check(c0,c1);if(b+status_in[2]>a)begin status_out[2]=1; end else begin status_out[2]=0; end end
                inc:begin {status_out[0],c0} = a+1;status_out[3]=parity(c0);
            status_out[1]=zero_check(c0,c1); end
                dec:begin c0 =a-1;status_out[3]=parity(c0);
                Mul:begin {c1,c0} = a*b;    status_out[3]=parity(c0);
                pst:begin c0=a; c1 = 0;status_out[3]=parity(c0);
                And:begin c0=a & b;status_out[3]=parity(c0);
                Or: begin c0=a | b; status_out[3]=parity(c0);
                Not:begin c0=~a; status_out[3]=parity(c0);
                Nan:begin c0=~(a & b);status_out[3]=parity(c0);
                Nor:begin c0=~(a | b);status_out[3]=parity(c0);
                Xor:begin c0=a ^ b;status_out[3]=parity(c0);
                Lst:begin c0=a<<b; status_out[3]=parity(c0);
                Rst:begin c0=a>>b;status_out[3]=parity(c0);
                default: $display("invalid entry");
            endcase
        end
   end
endmodule
Thank you.
