[Moved] charging 12v 175ah battery with 24v ups directly.
numair_noor
hi, i want to know if i can charge my 12v 175ah battery with my 24v inverter+converter directly or not. previously there were two batteries connected in series. but they were not giving the backup time as expected. they could only give half hour backup time for just 3 or 4 bulbs of 24watt power. which is very less. i am not sure if the ups is 12v or 24. but since i did not set up the ups. so consider it as 24 volts.
secondly i tried to experiment it with that, disconnecting one battery. and just using one. but just as i connected the battery directly, i saw some bubbles in the battery(battery is not dry battery). it has some kind of liquid in the battery.
now i have switched off the circuit untill i can get an appropriate answer yes or no. so please tell me as soon as possible.
regards,
muhammad numair
thanks so much for your time
Re: charging 12v 175ah battery with 24v ups directly.
Cant charge 12V battery with 24V !
You have probably bad batteries or device is bad designed or have some problem.
Need to identify that this is very immportant. Open device and see if there is some marks on PCB, try to find some documentation for device. Usually 24V UPS have space for two batteries, you can check space in device case.
Probably UPS try to charge one 12V battery with 24V voltage and you see bubles inside as bad chemical process inside battery cells as over voltage reaction, this can lead to sulfatization of lead plates surface.
Try to make photo and post in thread, or tell us UPS model number and manufacturer name.
thanks , i guess i should connect it back to its position.
