og2015
Newbie level 1
If connected to a good 12v source, fault light lights up the moment the inverter is turned on and no power to outlets, however, if I plug in a drill with trigger on, then turn on inverter, the drill runs and no fault light. When I stop the drill, fault light comes on and there is no power at the outlets.
Board label: Xantrex International (c) 2001 442-0097-98-01 Rev. 2
All auto style fuses appear to be intact and there are no obvious burn areas or fried components on the board.
Searching for ideas...
Thanks in advance for any suggestions.
