MOSFET pull down in linear region
matt11
I have a current sense IC powered directly from a battery. I want the current sense IC to be in the shutdown state when the 3.3V power supply is disabled.
I have added a dual N channel MOSFET circuit (see attachments) to achieve a pull down on the shut down pin (active low and internally pulled high) when the
3.3V supply is not present. The circuit seems to work in LTspice but I am concerned about one of the MOSFETS operating in the linear region. (VDS < VGS - VT)
Is it safe to operate the MOSFET in this configuration or is there anything I'm missing that is considered bad design?
I would be cautious with it if the 3.3V is diabled the gate of M2 doesn't float. I would add a discharging resistor between the gate and source of M2. Or use bipolar transistor. Otherwise linear operation has no any problem of MOSFET, it should be OK.
