Jepoy Baduria
Hi all,
I am building a dc-dc boost converter with a UCC27254 (up to 5A peak current source/sink) to drive the low side mosfet. My input voltage is 20V at minimum, and switching frequency is 100khz. I am using an LM7815 linear regulator directly connected to the input voltage, to generate a fixed 15V to power the mosfet driver. I have attached the schematic of the open loop converter. The n-channel mosfet is an IRFB3077.
I just realized that the LM7815 cannot supply more than 2.2A (as the datasheet says), so I'm worried that the mosfet driver cannot source/sink the 5A it was supposed to, even though this is only transient current.
Should I place parallel LM7815s to increase the current capacity? Or should I just increase the bulk capacitance (C10)? I thought of simply replacing the regulator with an LM338 linear regulator (5A continuous, 12A transient), but this IC is too costly for my budget.
Any help is appreciated. Thanks!
