FreshmanNewbie
Full Member level 6
I'm having an issue with the MIC4606-2YML evaluation board.
There is no voltage waveform at the LOAD side output connector during operation. The bus voltage, VBUS, is at 24VDC and the VDD voltage to the gate driver section is at 12VDC. The APWM and BPWM input signals are present (these are 180 degrees out of phase running at 12500Hz, both at 50% duty cycle) and the EN (enable) line is pulled up as expected. I had this working nicely yesterday using the PIC32MK MCM Curiosity Pro Dev Board. This morning, however, I do not see anything on the output. I have verified that the input PWM signals are present, the bus voltage is present, the ENABLE signal is high, and the MOSFETs appear to be "healthy" and non-shorted. Any thoughts on what might be causing the MIC4606-2 to not drive the full bridge FETs?
