MOSFET Control problem with PIC PWM Signal
jean12
Advanced Member level 2
Hello,can some body tell me what I can do for controlling my MOSFET here,I am applying a controlling signal but I don't get the output but the MOSFET are becoming highly hot.
Please Help.
Thanks.
  • Schema.pdf
Your H-Bridge Circuit is wrong. http://www.talkingelectronics.com/projects/H-Bridge/H-Bridge-1.html
You have to use 2 pairs of N and P Channel MOSFETS. Study how H bridge works. One N-Channel and One P-Channel MOSFET will be active at a time.
Where is the bias voltage for the MOSFETS? MOSFETS need a reverse voltage for the gate. Use design 6 from the above link.
The circuit I gave is for H-bridge for driving motors and not for DC to AC converter. Provide a detailed circuit with part names of MOSFETS and opto isolators.
Withou bias voltage for gate MOSFET will not work.
https://www.intersil.com/content/dam/Intersil/documents/an96/an9611.pdf
https://schematiccircuit.com/dc-to-ac-inverter-with-mosfet/
The opto isolator is HV400IP ,the signal is being generated by a Microcontroller PIC16F1827 using Tahmid blog ,it is generating two signals of 50Hz and 2 signals of 20KHz so those four are applied on the gate of the MOSFETs;when applying the signal the MOSFET (IRFP460) became very hot.
Please help.
hello Jean, Can get an idea from this ,try Six-output-600v-Mgds-Simplify-3-phase-Motor-Drives.jpg
So how can you help me with the MSOFET of the same types in H_Bridge??
Thanks.
Reactions: bandu
    bandu
Jean, One of my friend gave this note ,he said, he also download it from net ,this is PIC driving motor circuit, I think this may be helpful to you.
bandu.
  • P9-059.pdf
Jean ,read this page to get an idea
Bandu
Me I am using HV400 as drive and MOSFET IRFP 460;the PIC16F1827 is giving PWM signal of 20KHZ and 50Hz .
Can you please help me to think far on this implementation??
Thanks,please help
mosfet hi.gif jean see this
bandu
Hello I am using only N-Type MOSFET?and I found that it is possible to use them so help me with that.
jean .Did you find any solution ,for your mosfet control?
bandu
No,I didn't.
Please help.
