Mahmoud Abuzayed
Newbie level 3
Hello... I made temperature sensor using pic16f877a. NOW i want to send this reading using sms...
i want when i send for example "Temperature" to the phone connected to the pic it responds to me as message "Temperature is: 20°" i mean sms communication and i guess it is done by fbus and AT commands, my problem i cannot write the full source code i face problems... can you help me
I want to use Nokia 6300 by connecting(Rx to D+ and Tx to D-) of the usb cable connected to the phone.
Here is my code:
Here is proteus:
Here is my code:
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 // LCD module connections sbit LCD_RS at RB2_bit; sbit LCD_EN at RB3_bit; sbit LCD_D4 at RB4_bit; sbit LCD_D5 at RB5_bit; sbit LCD_D6 at RB6_bit; sbit LCD_D7 at RB7_bit; sbit LCD_RS_Direction at TRISB2_bit; sbit LCD_EN_Direction at TRISB3_bit; sbit LCD_D4_Direction at TRISB4_bit; sbit LCD_D5_Direction at TRISB5_bit; sbit LCD_D6_Direction at TRISB6_bit; sbit LCD_D7_Direction at TRISB7_bit; // End LCD module connections int temp; char text1[]="Temperature= "; char txt[17]; char terminator=0x1A; // AT commands initialization const char atc0[] = "AT"; // Every AT command starts with "AT" const char atc1[] = "ATE0"; // Disable command echo const char atc2[] = "AT+CMGF=1"; // TXT messages const char atc3[] = "AT+CMGS=\"+972597233195"; // Send message to cell number : 0123456789 (Enter your cell phone number instead of 0123456789) const char atc4[] = "AT+CMGR=1"; // Command for reading message from location 1 from inbox const char atc5[] = "AT+CMGD=1,4"; // Erasing all messages from inbox // temperature measurment function void Read_temp (void) { temp = ADC_Read(0); temp = temp*0.4887; IntToStr(temp,txt); Lcd_Out(1,1,text1); Lcd_Out(1,13,Ltrim(txt)); Lcd_Chr_Cp(0xdf); Lcd_Chr_Cp('C'); Lcd_Chr_Cp(' '); } void send_sms () { UART1_Write_Text("AT"); UART1_Write(13); //Enter UART1_Write(10) ; // CTRL+Z UART1_Write_Text("AT+CMGF=1"); UART1_Write(13); UART1_Write(10) ; Delay_ms(2000); UART1_Write_Text("AT+CMGS="); UART1_Write(34); UART1_Write_Text("+972597233195"); Delay_ms(100); UART1_Write(34); UART1_Write(13); UART1_Write(10) ; Delay_ms(1000); UART1_Write_Text("Teperature is: "); UART1_Write_Text(temp); // temperature sending UART1_Write_Text('C'); UART1_Write_Text(0x6F); UART1_Write(13);//Enter UART1_Write(26); UART1_Write(13); } void read_sms() { char uart_rd; if (UART1_Data_Ready()) // If data is received, { uart_rd = UART1_Read(); // read the received data, if(strcmp(uart_rd,"Temperature")==0) { send_sms (); } } } void main() { ADC_Init(); UART1_Init(9600); // Initialize hardware UART1 and establish communication at 9600 bps Delay_ms(100); // Wait for UART module to stabilize ADCON1 = 0b00001110; // Analog channel select @ AN0 TRISA=0b00000001; trisc=0; portc=0; Lcd_Init(); // Initialize LCD Lcd_Cmd(_LCD_CLEAR); // Clear display Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off while(1) { Read_temp(); delay_ms(100); read_sms(); delay_ms(1000); } }
Here is proteus:
