rahib
I have a switch that will give momentary input now i want to toggle my output with this input.if I press my button once it will switch on and pressing it second time will switch it off.I don't want to use transistors because that will make the circuit complicated.please suggest some IC .
I have searched for an IC EDE2208 it is perfect as per my requirement but its not available in my city .
secondly Is there any T flip flop IC available.
I know that D or JK flip flop can be converted into T flip flop but in this case my input should be feed as clock but there is only one clock pulse to change all the four output on an IC that means i need 4 clock pulse for 4 outputs.
one more thing if i use flip flop to toggle how will i make sure that my output is low whenever the circuit is switched on
thank you for replies
