zermelo
Junior Member level 3
Modelsim compile error: t_sfixed function call "not a globally static expression"
I get the following Modelsim error when compiling my design for simulation:
"# ** Error: tx_and_replica.vhd(362): Actual (function call "to_sfixed") for formal "i_x" is not a globally static expression."
The relevant code snippets are:
1) Port mapping: Line 362 is the s_tx_tmr conversion to signed fixed.
2) s_tx_tmr declaration:
3) Conflicting component entity:
I had this "globally static" Modelsim error before when using a case with the control signal length defined via generic. Now there are no generics involved in the conflictive type conversion.
What could be causing this?
zermelo
Solved. It looks like Modelsim does not like signal conversion in port mappings.
zermelo
U_ITPL_TTL_HIGH: lin_itpl
Generic map
(G_COORD_DEC => s_step_low_freq'length,
G_COORD_FR => 0,
G_SLOPE_DEC => 1, -- We need the sign bit, the slope is negative!
G_SLOPE_FR => -s_step_slope'right)
Port map
(-- Reset & clock/clock en
i_rst => i_rst,
i_clk => i_clk,
i_conv => s_tx_cr_p_zc,
-- Inputs
i_slope => s_step_slope, -- decimal value
i_x => to_sfixed(std_logic_vector(s_tx_tmr),10,0), -- integer value
i_x1 => to_sfixed(0,10,0), -- integer value
i_y1 => s_step_low_freq,
-- Outputs
o_data_rdy => s_ttl_data_hi_rdy,
o_data => s_ttl_data_hi_fx);
signal s_tx_tmr : unsigned(10 downto 0);
Library ieee_proposed;
library work;
use ieee.std_logic_1164.all ;
use ieee_proposed.fixed_pkg.all;
Entity lin_itpl is
Generic
(G_COORD_DEC : natural := 8; -- Applies to coordinates only
G_COORD_FR : natural := 2; -- Applies to coordinates only
G_SLOPE_DEC : natural := 1; -- Applies to slope only
G_SLOPE_FR : natural := 4); -- Applies to slope only
Port
i_rst : in std_logic;
i_clk : in std_logic;
i_conv : in std_logic;
-- Inputs
i_slope : in sfixed(G_SLOPE_DEC - 1 downto - G_SLOPE_FR);
i_x : in sfixed(G_COORD_DEC - 1 downto - G_COORD_FR);
i_x1 : in sfixed(G_COORD_DEC - 1 downto - G_COORD_FR);
i_y1 : in sfixed(G_COORD_DEC - 1 downto - G_COORD_FR);
-- Outputs
o_data_rdy : out std_logic;
o_data : out sfixed(G_COORD_DEC + G_SLOPE_DEC+1 downto -G_COORD_FR - G_SLOPE_FR));
end lin_itpl;
zermelo
zermelo
