776ft
Newbie level 6
I am working on a complex filter for wireless communication, 6-stage, biquards structure, for ideal inputs, the outputs is good enough. the image suppression (-2M Hz) is 70dB, but when mismatch occurs in the inputs (0.3dB in magnitude and 1° in phase), the image suppression have reduced to 34dB,(what i need in 35dB at least) which was run in TT case, process variation could make it worse.
considering adding it to 8-stage, and i simulate it, in ideal case, the image suppression is 90dB, but when I make it 0.3dB & 1° mismatch, the image suppression is still 34dB, i don't know whether it is proper.
and how should I improve the image suppression in mismatch inputs?
