Alberto Dan
Junior Member level 3
Hy i have a problem with a count down timer.I m new in microcontroller,i stardet to learned two month ago.Now i try to make a countdouwn timer from 99 to 0.Next i want to try to maket from 9999 to 0.I don't understant what about interrupt and i try to make it only from C.
Now i write a code but in Mikroc Give me to error:
1)temp1 = (value%10); //error opeator is not applicable to these operands
2) value = chose_value(); //error not enought parameters
and i don't understand why
I did not succeed for now to try my code to see if it's work because of this error.If anybody want to watch in the code and give some ideas what think about it...
I atach a photo with proteus schematics.
Thx werry much ,i need a help please!!!
My code is:
This is my schematic on proteus
My code is:
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 sbit en_enter at RA2_bit; double temp1 =0; double temp2 = 0; ///////////////////////////////Set PORTC output //////////////////// void toportc(int a) { switch(a) { case 0: portc=63; break; case 1: portc=6; break; case 2: portc=91; break; case 3: portc=79; break; case 4: portc=102; break; case 5: portc=109; break; case 6: portc=125; break; case 7: portc=7; break; case 8: portc=255; break; case 9: portc=111; break; default:break; } } /////////////////////////////////////Show The Time Function////////////////////////// void show_time(double value) { porta.ra3=0; porta.ra4=1; temp1 =(value/10); toportc(temp1); delay_ms(200); portc=0; porta.ra3=1; porta.ra4=0; temp1 = (value%10); //error opeator is not applicable to these operands toportc(temp1); delay_ms(200); portc=0; } ////////////////////////////////Chose value Function///////////////////////// double chose_value(double value) { double value =0; char new_encoder,last_encoder; while(en_enter == 0) { new_encoder = (porta & 0x03 ); if(new_encoder != last_encoder) { if(new_encoder.F1 == last_encoder.F0) value+=0.25; else value-=0.25; last_encoder = new_encoder; } if((value <0) || (value >= 100)) value = 0; show_time(value); } return value; /* while(en_enter ==0) { if(portb.rb4 == 1) { value++; delay_ms(300); } if(portb.rb5 == 1) { value--; delay_ms(300); } if(value == 100) value = 0; if(value <0) value =0; show_time(value); } return value; */ } ///////////////////////////////////Count_Down Function////////////////////////////////////////// void count_down(int value) { int i=0; portb.f1 = 1; delay_ms(10); for(i=value ; i>=0 ; i--) { show_time(i); delay_ms(990); } delay_ms(10); portb.f1=0; } //////////////////////////////////////Fumnctia MAIN////////////////////////////////// void main() { double value =0.0; ADCON1 = 0b00000110;//all portA as digital I/O TRISB = 0XFF;//SET PORT B AS IMPUT TRISC = 0X00;//SET PORT C AS OUTPUT for(;;) { value = chose_value(); //error not enought parameters count_down(value); } }
