ulaska
Member level 3
layaghi said:Hi ulaska
What is the maximum rate the
Davicom 9000E 100 pin,
Davicom 9000A 48 pin (new) and
SMSC lan91c111
can transmit data via the eternet connection?
thanks
Yes it can transmit data of course.
You can use a "Magnetics" between the Rj45 connector and ethernet controller.
magnetics is ie. Halo tg110 series. for coupling and signal levels.
i have a little experience about them but, of course you must have run a software (like TCP/IP server) in the microcontroller.
i am sure that there are lots of guys known well this issue.
