Micro inverter-batterry charger
mareeswaran
Newbie level 6
coimbatore
hi i have attached pdf file for inverter battery charger(12v/7Ah).
can i use the same circuit for (12v/40Ah) battery or any other changes in this circuit for battery Ah level increasing.
Thanks & Regards,
Mareeswaran.k
  • battery charcing circuit.pdf
40AH you will need a charging current rate of around 4 Amp. For this purpose your charging circuit will work provided you increase the current rating (6 to 10 Amp) of transformer X1 and diodes D1 & D2.
