[SOLVED] mic4451 error in orcad capture (green circle)
alielectric
I have a mic4451 and i give him the inputs but i don't know why the out put voltage is static zero please help me in addition in capture a green circle appears near the IC that have writen no template model in pspice
thanks for your attention
Have to tried with connecting the MOSFET, since the MOSFET driver is intentionally designed to drive mosfet,So try with MOSFET or try with >=15000pf load at the output(equivalent load to MOSFET...) as you can see the same test circuits in datasheet of MOSFET...it drives at least capacitive loads of >100pf
Thanks for your attention
I have found the problem solution
because mic4451 doesn't have a pspice model in pspice you should find a device that has pspice model it is the weakness of pspice that all of his libraries doesn't have pspice model
the spice model is not released from the micrel itself....
see here **broken link removed**
But you can test directly if you have component....
