Metrix 440 Vibration Switch
Mohammad_Pirzadi
Khorramabad, Iran
hi everyone
how can I jamp Metrix 440 Vibration Switch without tripping while the machine is working? i.e. how can I disconnect the vibration switch (for servicing) without shutdown the machine?
A simple (and possibly incorrect) suggestion is to connect a jumper across the two contacts which carry power, that is: (a) one going to the power supply, and (b) one going to the machine.
It could be the right suggestion only if your setup has the simplest possible electrical wiring. Or is your setup more complicated? Then you should post more photographs, and do not connect any jumpers until you get more expert advice.
