[SOLVED] memory restriction in keil. plz help
yasir23
Member level 1
Build target 'Target 1'
assembling mea.asm...
linking...
BL51 BANKED LINKER/LOCATER V6.22 - SN: Eval Version
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2009
"mea.obj"
TO "check.a51"
RAMSIZE(256)
CODE( 0X0000-0X1FFF )
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 0879H BYTE (105%) *
Program Size: data=8.0 xdata=0 code=2169
LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
MODULE: mea.obj (-----)
LIMIT: 0800H BYTES
Target not created
i m using kell and u can check my flash configure in word file.
how can i use increase the size in keil ??/
i m using 8051. its rom is 4k but here is code is 2169 ? what does it mean ??
what should i have to do... plz help
  • New Microsoft Office Word Document.doc
Free Tool No limitations
h**p://sdcc.sourceforge.net/
Free Open Source Software
SDCC
a retargettable, optimizing ANSI - C compiler that targets the Intel 8051, Maxim 80DS390, Zilog Z80, Z180, Rabbit 2000 and the Motorola 68HC08 based MCUs.
