drew_f
Newbie level 2
I usually measure PSRR with the DC voltage applied to the DUT through a 50ohm resistor, and the AC voltage coupled in with coupling caps. However, this part I'm working with exhibits positive PSRR, when measuring it this way. I'm told that the Vcc pin needs to see a low impedance throughout frequency. Any recommendations on how to make this measurement? I've heard some suggest using bypass caps...but that would reduce the AC signal to negligible levels once it reaches the DUT. Any thoughts?
