Preethi21
Newbie level 2
I am using a Bernoulii Binary Generator to generate my data signal for a Direct sequence spread spectrum model I am designing on SIMULINK. The specifications of the generator block is as follows :
Probability of zero : 0.5
Initial seed : 61 ( random number )
sample time : 0.6
Frame based outputs
Samples per frame : 100
I wish to calculate the power of the signal generated from this block. How can I do this in Simulink ? Or Matlab ? Are there any blocks in SIMULINK which I can use to measure the power directly or indirectly ?
sample time : 0.6
Frame based outputs
