luck09
Newbie level 5
If I have a 12VDC motor (MAXON MOTORS - 2140.934-61.112-050 - MOTOR, 12VDC in the link below)
https://datasheet.octopart.com/2140.934-61.112-050-Maxon-Motors-datasheet-520919.pdf
What is the maximum voltage supply for this DC motor so that the motor will not be burnt? Because I don't see that value in the datasheet, can I use 15VDC for this motor?
Actually, I am trying to control this DC motor. But I don't have 12VDC power supply, just 24VDC power supple with the capability of adjusting down to about 15VDC. I connected and there is no problem, but still want to make sure.
For the motor I have, there are four outputs from the circuit, including two common GND. I think they are outputs from encoder, channel A, channel B, GND. There is no +5V for encoder because they have power from the power of DC motor. However, I still don't understand why they have two GND. Could anyone explain?
Thank you very much!
