matrix transpose code for Implementation of 2D fft
shan14
Member level 3
Hi
I am doing 2D fft in VHDL . My algorithm is
1) 1D fft then
2) transpose of the output of 1D fft
3)again 1D ft of those transpose output
4)again transpose the 1D fft
So in this, I am using following matrix transpose code .
My question is that,is this matrix transpose code correct for doing 2D fft???
  • Transpose.txt
Have you made a testbench? That would be the best way to test it.
There is one error in that x is never reset back to 0, so if X overflows the simulation will error.
Hello shan14,
in regards to your code, did you synthesize it successfully? I just copy and paste the code and I got an error due to size mismatch. It is just the size of "t1", you have to set it to 2 downto 0.
From my point of view, there are couple of things I would coded differently. In the process sensitivity list, I would put just the clock signal and reset. I think, maybe you can put the assignation "output_there <= '1'" inside the "elsif(rising_edge(clk)) then".
Also, as TrickyDicky suggested you, a testbench is the best way to test if your design behaves as you expect
Best regards.
1) 1D fft then
Are you sure this is the correct algorithm? I ran across this method on stackexchange. It seems that the OP changed their code and verified that it worked with the algorithm given by Paul R.
I also don't understand where your input matrix is, the input is just a single vector. Is your data streaming? If so how do you determine where the rows/columns of your matrix are located in the stream?
Reactions: shan14
    shan14
Hi
I am taking 16 point FFT. so 16 inputs are coming one by one. I am considering it as a 4*4 matrix.
so while doing transpose of the output of 1D FFT, I am getting transposed output which is correct.
My doubt is that is this way correct??
Hi shan14,
I guess you are using the signal "output_there" to indicate that you have buffered the entire matrix and you are going to output it. So, in my opinion you should add a "start" input port in your design to indicate your block to start receiving each point of the 4*4 matrix, otherwise it considers every input data as matrix data.
After adding the start input port I would say the code is correct.
Anyhow in a sequential process, I would not add any signal at the sensitivity list other than clock and reset. And if possible, in my opinion is a good practice not to have many nested if statements.
Kind regards.
Reactions: shan14
    shan14
