matlab floating point doubt
achaleus
Member level 5
Bangalore
Hello all,
18446744073709551615 - 3 and 18446744073709551615 output in cmd line in matlab giving same output as 1.8447e+019.
my ques is how to see exact value as 18446744073709551612
Hi Achaelus,
you can change the format of the display in File - Preferences - Command Window - Text display (Numeric format, Numerid display) .
You can use also the "format" command. Type "doc format" or "help format" in the command window for an explanation.
Nevertheless, the accuracy of the representation is insufficient for distinguish 18446744073709551615 from 18446744073709551612.
For example, if you type the command line
>> 18446744073709551615 - 18446744073709551612
you get as result
ans = 0
See help for the "eps" function ("doc eps" command).
Regards
Z
