Manchester encoding is pretty easy if you do it on a byte by byte basis. I assume
you know about manchester encoding, so I'll concentrate on the code.
Because its 2 manchester bits for one data bits, we are doubling the datarate so,
you're putting a byte in, and get 2 bytes out of the encoder.
All you really need is a small lookup table, with 16 entries. You can just write this by hand, as long as you decide which transistion for each bit. I use 0 = 10, and 1 = 01.
So an upward transition for a 1, and a downward one for a 0.
0000 10101010
0001 10101001
0010 10100110 etc....
The code is simple. Heres some pseudo-code.
Move 'inbyte' into W ; puts in the W register.
AND with '00001111' ; masks lower nibble, just gets rid 4 MSB's.
Call lookup table ; now that we have a 4 bit number, get lookup table entry.
Move W into 'Lowbyte' ; and move that into the 'Lowbyte' register.
SwapF 'inbyte', W ; swaps nibble of inbyte, and stores result in W.
AND with '00001111' ; again, gets rid of 4 MSB's.
Call lookup table.
Move W into 'highbyte'
Theres many methods using the lookup table. But remember, the way lookup tables work in PIC assembly, the value in the W reg, is the number of lines to 'jump', where it lands, puts the value on that line in the W and returns (with the retlw command). So, because the LUT is only 16 lines long, you must make sure that you get rid of the first 4 bits of a byte when you call the LUT. (maximum value 15). Hence the 'AND with '00001111' line. The swapf command, is handy, and allows us to do the same thing again, but for the first 4 bits (highbyte).
If you're planning on sending some data serially, quickly, you might want to put highbyte and lowbyte into a circuilar buffer (high byte first).
If you do a search of this forum, you'll find plenty of info, and many, many links to sites that explain it far better than I can. Along with source code, for any language.
