Making an auto ranging uCurrent (switching between 0.01, 10 and 10kOhm)
markbng
Junior Member level 1
I want to make an auto ranging uCurrent. The measured current goes through a 10 mOhm, 10 Ohm or 10k resistor. I want to be able to switch between these measurement resistor branches with a switching N-fet or something. so all these resistors are connected with each other in 1 point and the other end goes to the drain of a N-Fet. all source connections are connected to ground. The source of the selected measurement resistor value has a high voltage to enable this resistor. But my problem is the 10k range. This measures nA (10e-9). if other branches leak nA, then I have a problem. What FET can I use that has a low capacitance and very high impedance (GOhm)? Or do you have another solution. How can I switch between the measurement resistors? I will probably change the FET in the design. First the FET and than the measurement resistor to ground. Can someone help me in this part of the design. I want to measure nA, so only a leakage of a couple of pA is exeptable. Any help is appreciated.
Kind regards,
Mark
What is this?
* A current source in the microAmperes range?
* Or a measurement device (meter) for currents in the microamperes range?
* Or someting else?
DC? AC? What frequency range, what waveform?
autoranging?
What range?
If you have a circuit (solution) in mind, then show a schematic or at least a draft.
But if you are looking for a solution, then give clear requirements.
Like: Values with units, ranges, tolerance, accuracy, precision, resolution...
Why "low capacitance"? A MOSFET model (datasheets) usually comes with 3 different capacitances. Which one?
What does "low" mean? as value..
Nothing about voltages, power supply, how to be measured, how to be controlled?
Klaus
if your resolution is 1 mV and need low input offset V and low input bias current for a Howland Current Source, there are many to choose from.
Here's my list from one source Iin < =1pA Vio<=10uV in stock.
But you need high current for mohm resolution so use an emitter follower and/or a one of the above 170 items with 85mA drive capability and 0.01 pA input current. You won't need 50 MHz GBW but this certainly has come a long way from the uA741
Small signal relay, like the ones used in IC testers ?
You would have to do a cal cycle to manage its contact R, but leakage would be 1,000 Meg Ohms
min on many.... Many low current drive.
Regards, Dana.
LaTeX Commands Quick-Menu:
