abbaszandilak
hi everyone. i want to make a tachometer with arduino mega. my main approach is using IR receiver and transmitter to capture the radial compressor blades' movement and I'm using BRQM100-DDTA sensor but I have some troubles like the sensor malfunctioning at high speeds.do you have any suggestions or idea about this?can I use the simple IR sensor and transmitters .i have to say that my compressor numinal speed is about 90K rpm.
thank you all
thank you edaboard
thank you all
thank you edaboard
