Magnetization Branch in a transformer
madeza
Member level 4
Arequipa / PERU
How can I calculate the magnetization branch, I mean magnetization resistance and reactance. My only data is the nameplate of transformer: Apparent Power, Primary and secondary voltage, X/R ratio
Thanks for your support
Can you carry out test on the transformer? If you're allowed to do so, may be you can find the parameters via open- and short-circuit tests.
i is not possible to fine transformer megnetizing branch value from nameplate of the transformer. it can only be calculated from open / short circuit tests.
ok buddies, but I can't carry out any test... It`s a big size transformer 168MVA and the only data available is the nameplate... well, thanks for your replies...
It is not possible without doing open circuit and short circuit test on transformer.
Umesh.
