mineshpatel88
Junior Member level 1
suggest me the topic of embedded and image processing..
which is best of them ..
The area that you are saying is very vast so you need to first look for particular domain -
Like In embedded system you need to chose some thing like what domain you want to work for an example like communication system for data transfer with advance protocol ( Protocol design and communication) or Video transfer system from camera ( Video Processing) or efficient Network Traffic system ( Networking) or Self calibrating measuring system ( Measurement and control) etc...
Like in Image processing you can choose the topic like Character reorganization for Handwritten Scripts or Signal generation system with Image filtering methods or Image compresses-ion for Binary image contents or motion estimation in the video frames etc....
First choose what you want to do the question you ask is at very very high level...
Good Luck
As you are looking for master's degree the work must be meaningful and must be vast....
One of the project that I can thought on ARM7 ( I think you have LPC2148 Philips Processor) is SD card interfacing and Porting File system ( FAT32) for data read write operation on the SD Card from PC based application( PC based SD card system) ...... Or storing some sensor data ( Data logger application)....
Or even multiple sensor interfacing system for home automation with control .....Many things can be done like ( Fire Alarms, Air conditioner (A/C) control with auto temperature detection )
On the DSP processor many things can be thought of Like real time analysis of speech and music signal ( I mean identification), hardware based voice recognition system etc....
Good Luck
