Yarrow
Member level 2
Hi all.
I am trying to do LVS using std. cells from foundry. I am using Cadence tools with Calibre LVS. I am currently using an inverter (with input and output pins) as a test case.
1. Anyone know how to handle inherited gnd/vdd in layout? I see them in the schematic netlist, but I dont know how to include them in the layout. Are there any settings I can set in Calibre LVS.
2. So far I have only achieved to perform LVS by blackboxing the standard cell. I am aware of that this only checks the connections/routing between the standard cells and it does not check the layers inside the standard cell. (I am referring to the Metal1 routes in the standard cell)
I would like to be able to check the routing layers in the standard cell as well. When I run Hierarchical LVS (.gds exported from layout) I get the following errors:
"Nothing in layout"
"Corresponding cells could not be identified"
"Nothing in layout"
I used CALIBRE DESIGNrev and verified that the exported .gds file has all the cells and layers.
Can anyone point me in the right direction?
Thanks in advance.
Yarrow
"Nothing in layout"
"Nothing in layout"
Thanks in advance.
Yarrow
