LVS error in NAND3 design
hoanguit
vn
hi everybody, i had finished layout and schematic,i built with no error but when i built LVS is error,i can't find them.please help me.thanks all
LVS is error
Just stating the obvious - we need more information if you want help!
Keith
Re: LVS is error
i do nand3, with input name is ina,inb,inc, output name is out.i begin to study about layout so i have a lot of hardly.error is pin name input,isn't it ?
schematic is pass, DRC is pass,extract is pass but LVS isn't pass if you need my file i can upload for you
LVS is error
That still doesn't help. We need to see the schematic, layout and the LVS error.
Keith
LVS is error
you can not assign pins arbitrarily. although when you swap pins the functionality remains, if the pins are not connected in layout the same way they are in schematic then lvs will not pass. this is common mistake i've seen in static logic layout.
Re: LVS is error
i have just fix some error but when i check output of LVS,it have some bad from schematic.i will share to everyone.please check help me
Re: LVS is error
state the exact words of LVS error????? and attach the schematic of your circuit?
