rituparnasaikia
Member level 3
- Joined
- Feb 1, 2006
- Messages
- 57
- Helped
- 3
- Reputation
- 6
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Bangalore, India
- Activity points
- 1,696
I have failed generating UART0 interrupt for LPC2103 in Keil Compiler. I can send data using pooling method.
Bellow is the code:
Bellow is the code:
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 #include <lpc210x.h> #define Fpclk 11059200/4 #define UART_BPS 9600 /* ??????? */ #define LN 30 volatile char RcvNew; /* ?????????? */ char RcvBuf[LN]={0}; /* ????????? */ int RcvNum; /* ????????? */ /********************************************************************************************************* ** Function name: DelayNS ** Descriptions: ** input parameters: uiDly ???,?????? ** output parameters: ? ** Returned value: ? *********************************************************************************************************/ void DelayNS (int uiDly) { int i; for (; uiDly > 0; uiDly--){ for(i = 0; i < 50000; i++); } } enum OptCodeType {PUSH,POP,CLR,CHECK}; int SentFIFO(int OptCode,char OptNum) { #define FIFO_Size 32 static char FIFO[FIFO_Size],ptIN,ptOUT; switch(OptCode) { case PUSH : if(ptIN==(ptOUT+1)) return 0 ; else FIFO[(ptIN++)%FIFO_Size]=OptNum; return 1; case POP : if(ptIN==ptOUT) return(0); else return(FIFO[(ptOUT++)%FIFO_Size]); case CLR : ptOUT=ptIN; return 1; case CHECK: if(ptOUT>ptIN) return(ptOUT-ptIN); else return (ptIN-ptOUT); default: return 0; } } /********************************************************************************************************* ** Function name: UART0_IRQ ** Descriptions: ???????? ** input parameters: ? ** output parameters: ? ** Returned value: ? *********************************************************************************************************/ void __irq UART0_IRQ (void) { int i; while ((U0IIR & 0x01) == 0) { /* ????????? */ switch (U0IIR & 0x0E) { /* ?????? */ case 0x04: { /* ?????? */ RcvNew = 1; /* ???????? */ for (i= 0; i < 8; i++) /* ????8??? */ if(RcvNum<LN) RcvBuf[RcvNum++] = U0RBR; } break; case 0x0C: /* ?????? */ RcvNew = 1; while ((U0LSR & 0x01) == 0x01) { /* ?????????? */ if(RcvNum<LN) RcvBuf[RcvNum++] = U0RBR; } break; case 0x02: default: break; } } VICVectAddr = 0x00; } /********************************************************************************************************* ** Function name: UARTInit ** Descriptions: ?????,???8????,1????,?????,????115200 ** input parameters: uiDly ???,?????? ** output parameters: ? ** Returned value: ? *********************************************************************************************************/ void UARTInit (void) { int uiFdiv; U0LCR = 0x83; /* ??????? */ uiFdiv = (Fpclk / 16) / UART_BPS; /* ?????*/ U0DLM = uiFdiv / 256; U0DLL = uiFdiv % 256; U0LCR = 0x03; /* ????? */ } /********************************************************************************************************* ** Function name: UART0SendByte ** Descriptions: ?????????,?????????,?????? ** input parameters: uiDat ?????? ** output parameters: ? ** Returned value: ? *********************************************************************************************************/ void UART0SendByte (char uiDat) { U0THR = uiDat; /* ???? */ while ((U0LSR & 0x20) == 0); /* ???????? */ } /********************************************************************************************************* ** Function name: UART0SendStr ** Descriptions: ???????? ** input parameters: uiStr ????????? ** uiRcvNum ???????? ** output parameters: ? ** Returned value: ? ***************************************************************************************8****************/ void UART0SendStr(char const *uiStr) { while( *uiStr) /* ????????? */ UART0SendByte (*uiStr++); // UART0SendByte ('\r'); // UART0SendByte ('\n'); } /********************************************************************************************************* ** Function name: main ** Descriptions: ??JP6??,????????,??0?????? ** input parameters: ? ** output parameters: ? ** Returned value: ? *********************************************************************************************************/ int main (void) { int i; PINSEL0 = PINSEL0 & (~0x0F); PINSEL0 = PINSEL0 | 0x05; /* ??I/O???UART */ RcvNew = 0; UARTInit (); /* ????? */ U0FCR = 0x81; /* ??FIFO,??8?????? */ U0IER = 0x01; /* ?????? */ // IRQEnable (); VICIntSelect = 0x00000000; /* ??????????? */ VICVectCntl0 = 0x20 | 0x06; /* ???????????? */ VICVectAddr0 = (int)UART0_IRQ; /* ?????? */ VICIntEnable = 1 << 0x06; /* ?????? */ UART0SendStr ("==================Hello! ZhiHui Chengjiang======================\n"); UART0SendStr ("ARM: I'm ready now,sent me the massage!\n"); while (1){ if (RcvNew == 1) { /* ???????? */ RcvNew = 0; /* ???? */ UART0SendStr (RcvBuf); /* ??????? */ for(i=0;i<LN;i++) RcvBuf[i]=0; RcvNum=0; } } return 0; }
