GBHT
Newbie level 6
if i give a square wave input to a lowpass filter(1st order) whose corner frequency is much higher than the input frequency, at the output do i get a square wave or triangular wave(since 1st order lowpass is an integrator)?
if cutoff frequency is 10kHz and if i give an input of 50Hz then i thought i will get a square wave at the output since most of its harmonics pass through it..but i am getting triangular wave..is it correct? if yes then how?:arrow: thanks in advance
