santoshkskkr
Newbie level 2
I had a card in which while doing some soldering work for mounting component, the resistance between 3.3V and ground came down from 460ohm to 3.6 ohm. I tried to debug it. I found for solder ball which i removed but of no use .I also removed all the capacitors connected to 3.3V and Ground but the resistance is same. What could be the problem and how can i solve it.
