LOS Alignment software needed
hitman1988
Member level 5
iraq
Hi all
I'm a wireless Telecoms engineer need a software that can detect the antennas I want to align and give the angle difference between the two antennas so I can make the signal between the two links . the frequencies we normally use , 5GHz, 11Ghz , 17GHz
regards
pathloss maybe
Use GPS etc to calibrate.
You can get coarse result, then tuning in field to get the maximum receiving power level.
